Discussion topic: Stream HDMI cable
This message was authored by: Cooper+D
Stream HDMI cable
Would the HDMI cable that is supplied with the stream puck be suitable to use with Apple TV or would you need to purchase a different one, if so what would be recommended? Thanks in advance.
All my opinions are my own.
Re: Stream HDMI cable
Do you mean Apple TV box OR Apple TV+ app?
Avatar for Cooper+D
Level 5 icon
@Exiled-in-HH  It's the Apple TV box, you don't need an HDMI cable to view the app.
The Apple TV box can test a HDMI cable to check the cables quality😉
Avatar for Cooper+D
Level 5 icon
@Exiled-in-HH  can you explain how the Apple TV box does this and I can look out for it.
Apple TV box ... Settings ... Video and Audio ... Check HDMI Connection😉
