Discussion topic: Sound problem & fast forward problem.
Message posted on 12 Feb 2026 06:28 PM
Hi.
Having problems with sound today. Intermittently, the sound will go off for around 40 seconds. Then it comes back.
Also, we tried to catch up with a program today, but it was forwarding slower than the 30x asked for, and eventually, the "Technical Fault' message appeared with a blue screen. Tried again, but the same thing happened, even after restarting everything.
Thanks for any help.
Message posted on 13 Feb 2026 08:30 AM
Re: Sound problem & fast forward problem.
@winehouse Depending on just how you are watching, but it is possible that an App refresh may help. Go to Settings & System management and under Reset choose App refresh, it takes a short while but wait until it returns you to the Home Screen and see if that helps.
Message posted on 13 Feb 2026 08:39 AM
I'll try later.
