Discussion topic: Sound loss
This message was authored by: DavidHood
Message posted on 24 Aug 2024 12:27 AM
Sound loss
Intermittent and short term sound loss on sky stream. Puck working well. Have disconnected puck and restarted but no change. Problem is on all channels and occurs every 10-15 mins for 30-40 seconds. Very annoying!
Find out more
Message posted on 24 Aug 2024 07:27 AM
Re: Sound loss
@DavidHood can you post how your puck is connected and if you have a soundbar or similar includecthe make and model of your TV and audiomkit. If you only listen through your TV's speakers try changing the audio setting onnthe puck to PCM which is a straight stereo signal which any devicecshould deal with without issue.
This message was authored by: CinderKona
Message posted on 24 Aug 2024 05:49 PM
Re: Sound loss
I get the same and have to restart to resolve. I have a home cinema set up but only the puck has shown this issue.
