Discussion topic: Sound cutting out
Message posted on 13 Apr 2026 06:36 PM
Sound cutting out
Puck is connected with Ethernet cable. Sky service checker says everything is good. Turned the puck off at the wall and left it. Basically followed all the guidance
But, sound is constantly dropping out when watching all channels, Netflix etc
It's not the TV either as we just a got a new one and the fault didn't change.
Message posted on 13 Apr 2026 07:07 PM
Re: Sound cutting out
@CeeW Have you tried going to Settings, Picture and sound, and select Sound. What does it say under Digital audio output HDMI?
Have you selected it and change to one of the other options?
Message posted on 13 Apr 2026 08:35 PM
It said 'auto' so we're now trying Dolby digital plus.. we can work through the other options if that doesn't work
thanks
