Discussion topic: Sound and display
This message was authored by: Lizgreen67
Sound and display
hi can someone help my I have a puck when I fast forward the adverts i loose the sound and the screen goes grey I have tried everything
This message was authored by: Stephen+Mourton
Re: Sound and display
@Lizgreen67   Hi, I have to presume you have paid for ad skipping.  Does this happen on all channels or just some, if you which ones are the most problem?  Does it happen on Streaming channels like Netflix?  Sky's own channels have a Skip Adds button on screen which normally works very well.  Some of the other channels I have found it is better to wait a few moments until the adverts actually start then fast forward.  I hope this helps.
Have you tried a settings restart?
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
Also, have a try at the Pucks sound setting options, like changing to Auto or PCM and see if that helps.
Avatar for Lizgreen67
Hi no it's if I am watching a program from the play list it's driving my dad mad bless him because it keeps happening I have done all the trouble shooting
Yeah I have done all of the trouble shooting  it's on a puck some times it works fine the last couple of days it's been happening a lot
@Lizgreen67   So it is just when watching from the Playlist?  I know from my own experience that the ad skipping works better when playing back some channels than others as they all have different systems, and  have the same problem.  As I mentioned tell your father not to try add skipping until the program he is watching stops for the adverts, waits for the sponsor message, and wait for the actual adverts to start, if you try and do it too quickly it will do exactly what you are experiencing.  It is frustrating I know.  If that isn't the solution maybe someone else can suggest something.
Excellent thank you so much for your help I am very grateful
