Discussion topic: Sony hts40r 5.1 to projector and screening box connect
This message was authored by: Thomasv6
Connecting a sony hts40r 5.1 and projector to the screening box
Re: Sony hts40r 5.1 to projector and screening box connect
Hi @Thomasv6
You will need to provide more information? What exactly is your query? The Sky stream box has HDMI output and supports HD and UHD 4K.
MikeAlanR
This message was authored by: Mister_Dalek
@Thomasv6
Not easily would be the simple answer.
Not unless the projector has an HDMI input & an optical or HDMI ARC output to feed audio out to the soundbar.
Alternatively you'd need an HDMI audio extractor box which can convert the HDMI audio to optical to send to the soundbar and then pass through the video to the projector. Would need to be HDCP compliant too.
