6
This discussion topic has been answered Discussion topic: Sky streaming buffering
This message was authored by: My+mike
My sky streaming keeps buffering. My wifi speed is poor, but sky says ut is ok.
Avatar for My+mike
This message was authored by: My+mike Answer
Re: Sky streaming buffering
Getting 51mb. But still glitching occassionally
This message was authored by: Mister_Dalek
Ignore Sky. If your WiFi speed is poor then that is why you are experiencing buffering.
What speed is the puck receiving? Use the network check on the Netflix get help menu. Anything less than 30Mbps will cause you issues.
Avatar for My+mike
This message was authored by: Nigelb1972
@My+mike it's possible that you're WiFi connection isn't stable or is suffering from some interference. Try connecting via ethernet if you can. Also, be aware if others in the house are also using the internet for data heavy applications, it could affect the speeds your getting at the puck in bursts which could lead to buffering
@My+mike  you marked this as an answer ... answers indicated the post is a solution ... what you made was a response to a question😉
This message was authored by: Peaanutt
I live on my own and my internet connection seems fine
This message was authored by: Schem2101
Sky stream is shocking while watching live TV
