Discussion topic: Sky streaming box not working
This message was authored by: Bradford23
Message posted on 08 Oct 2025 12:48 PM
My sky streaming puck is not connecting to my TV. It says to buy sky home anywhere but I only have 1 puck. On the app it says pending return for the puck but you can see from my account that's not correct. I need to have it set as my main puck.
Find out more
Message posted on 08 Oct 2025 01:17 PM
Re: Sky streaming box not working
Hi @Bradford23 This is a customer forum so you are not addressing Sky. To get this matter resolved you will need to call Sky.
To get past the chatbots stay silent and you will eventually be put through to the customer services team.
