Discussion topic: Sky stream
This message was authored by: Dan9011
Message posted on 26 Aug 2025 05:43 PM
Sky stream
My sky puk keeps saying software update. But just resets and does the whole thing again. Can't seem to get it working
Message posted on 26 Aug 2025 05:45 PM
Re: Sky stream
A common fault. Best thing to do is connect it direct to your router using an ethernet cable to allow the software update to complete. You should then be able to switch to WiFi.
Find out more
Message posted on 26 Aug 2025 07:13 PM
Re: Sky stream
Assuming this is happening when first setting up your Sky Stream puck.
If not, still follow the same advice below.
Follow carefully the steps in this Sky help article;
Sky Community Superuser. What is a Superuser? Click here to find out
