Discussion topic: Sky stream
This message was authored by: Seabass14
Message posted on 23 Jul 2025 06:23 PM
Sky stream
Watching a channel, and picture and sound randomly stop. Checked all connections, all fine, not overheating, checked broadband connections all fine. Just chanells randonly stopping. Very annoyed
Message posted on 23 Jul 2025 06:33 PM
Re: Sky stream
Have you checked the broadband speed actually being received by your puck?
To do this, open the Netflix app, navigate to the get help menu and run a network check. What speed is reported?
Find out more
Message posted on 23 Jul 2025 06:36 PM
Re: Sky stream
If it's been fine previously
If you have not done so, would suggest trying a restart of your Sky Stream puck.
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
Sky Community Superuser. What is a Superuser? Click here to find out
