Discussion topic: Sky stream
This message was authored by: ElaineD69
Sky stream
My sky stream keeps freezing during a programme, sometimes comes back itself by taking itself back to home page and others I have to disconnect power to puck and reconnect. Has happened 6 times just this evening!!!!
This message was authored by: Stephen+Mourton
Re: Sky stream
@ElaineD69   Hi Elaine, often the reason for this can be two fold, both internet connected.  Firstly have you checked you have a good internet connection.    Go into Settings then Network and see what if says about your internet speed.   Another reason can be related to your router.  If it is not connected to your puck via an Ethernet cable does it have a clear line of sight to your puck, and are both your router and puck away from other objects and the router is not next to a window or mirror.  All these can be the cause of your problem. I hope that helps.
