Discussion topic: Sky stream
This message was authored by: JulieC1971
Sky stream
I am trying to apply for sky stream and broadband, however the app crashes right at the end. I called sky and cannot get the same package at the price on the app.
Re: Sky stream
Hi @JulieC1971
We are fellow subscribers, you will need to call sky.
You say your using the app? Do you already have some Sky services? If so try using the website at Sky.com instead of the app, however you can't usually switch to Sky steam online as an existing subscriber. You should be able to order broadband online on its own.
MikeAlanR
