Discussion topic: Connect tv av receiver sky puke and amazon stick together
This message was authored by: EwelinaS
Hello Could You please help me to connect all of that propely together?
LG OLED55C16LA
YAMAHA RXV4A
FIRE TV Stick 4k Max
Sky puke
Do I have to use 4 remote control????
Re: Connect tv av receiver sky puke and amazon stick together
@EwelinaSyour Sky remote and your Fire remote should be able to turn on the tv and switch it to the right input straight away if HDMI Control/Simplink is enabled.
If your sound setup is controlled by HDMI you should also be able to control volume with them two also.
You won't be able to control Sky Stream with your Fire remote and vice versa.
So in short, as long as you can control volume with your fire and sky remotes you should hopefully be able to go down to 2 remotes.
LG OLED55C16LA
YAMAHA RXV4A
Sky puke
Connect the Yamaha AVR to the TV via HDMI eARC (HDMI port 2 on the TV I think) then connect the Firestick and Puck (or puke if that's what it does for you) to two other HDMI ports on the TV.
With HDMI CEC control enabled on all devices and the Stream puck remote paired to the TV, you should be able to control everything with either just the puck remote or the Firestick remote.
Have the audio set to passthrough on the TV and on the puck, and set the Firestick to Best Available.
Use certified high speed HDMI cables of the same length and spec for best compatibility.
