Discussion topic: Sky stream
This message was authored by: Philstewart
Sky stream
Why can't I speak to someone from sky to organise sky stream box
Re: Sky stream
@Philstewart  Have you called?  Are you staying in the line and not saying anything or responf=ding to the prompts.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Re: Sky stream
You can. What problem are you having with doing so?
