Discussion topic: Sky stream
This message was authored by: Metre
Sky stream
Can I use sky stream puk in my garage off my WiFi extender
Re: Sky stream
You should be able to use the puck anywhere on your property that has access to your broadband
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
This message was authored by: Bigal66
Re: Sky stream
If you get a decent signal from the extender should be no problem 👍
