Discussion topic: Sky stream
Message posted on 03 Jun 2024 04:21 PM
Sky stream
Do I need a separate router to set up sky stream in my second room?
Message posted on 03 Jun 2024 04:37 PM - last edited: 03 Jun 2024 04:38 PM
Re: Sky stream
No, assuming you have a good wifi signal the 2nd puck should connect to it.
All pucks within your home need to be connected to the same network/router.
Message posted on 03 Jun 2024 04:47 PM
Re: Sky stream
If there are issues with wifi due to the construction of the property powerline networking maybe a solution🤔
