2
This discussion topic has been answered Discussion topic: Sky stream.
This message was authored by: Josie3
Sky stream.
Trying to get sky stream going, but it's a nightmare. Any hints?
This message was authored by: BenJoBanjo Answer
Re: Sky stream.
Connect it to your router with an ethernet cable to begin with. Once it's (hopefully) stable and has done its software updates you can switch to using WiFi.
This assumes you have a decent, fast and stable broadband connection in the first place of course.... 25Mbps absolute minimum.
Re: Sky stream.
Could you elaborate some more on your issue?
If this is a new setup and activation, are you getting any error messages, plus read work through this setup help article;
https://www.sky.com/help/sky-tv/sky-tv-stream/setting-up-sky-stream/articles/setting-up-sky-stream
Re: Sky stream.
Answered - Go to Answer
