Discussion topic: Sky stream
This message was authored by: Iona2000
Sky stream
My sky stream keeps freezing and saying its a technological issue has anyone had this problem
This message was authored by: Jones_The_Cat
Re: Sky stream
This is always usually related to your broadband speed.
Is your puck connected via WiFi? Is it possible to connect with ethernet to your router?
What broadband speed is the puck receiving? To find out, open the Netflix app, navigate to the get help section and run a network check. Report back with the result.
Avatar for Iona2000
Re: Sky stream
It's currently through virgin media WiFi as I'm waiting for sky broadband to be connected next week
Re: Sky stream
@Iona2000 as its connected via WiFI the best thing to try is to connect via ethernet to the router, and in the Sky Stream puck settings, ensure that the wifi option is set to disabled. Once you disable the WiFi in settings it always best to reboot the puck by unplugging it for a couple of minutes. If you don't disable Wifi in the settings it will keep switching over from ethernet to Wifi and likely will continue to cause issues.
Sky Stream, Sky Glass Air and former Sky Broadband customer
