Discussion topic: Sky stream
This message was authored by: Kevin712
Sky stream
Not long got sky stream but it keeps getting technical difficulties trying to load channels, is there anyone else have that very often? Im thinking its a waste of money.
Re: Sky stream
Hi @Kevin712
What is your WiFi / Internet connection like? It sounds like poor connectivity.
MikeAlanR
Re: Sky stream
I'd suggest opening the Netflix app on your stream puck, going to get help and then check your network.
this will tell you the download speed the stream puck is getting. I'd suggest running this a couple of times to get an average speed.
