Discussion topic: Sky stream won’t turn my tv on or off
This message was authored by JLGriff This message was authored by: JLGriff
New to Sky Stream all set up ok except on neither tv (Panasonic and Blaupunkt) will the remote turn the tv on or off. Volume control works.  I have tried holding down the power button but this has no effect.. any suggestions?
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
Re: Sky stream won’t turn my tv on or off
Can't your TV remotes control the Sky Stream Pucks?
Exiled in HH
JLGriff
No the new Sky stream remotes will adjust the volume but will not turn the tvs on or off.  We are having to use the old Sky Q remotes to turn the tvs on and off
This message was authored by Munkeh This message was authored by: Munkeh
Hey,
You might need to go back into Settings > Remotes and reset your remote try a diffrent setting i had this problem it went from stage 2 of 5 and it just turned my sound up and down but not turning the TV but i found out resetting the remote and going to Stage 4 of 5 it done the volume and switch TV on and off.
Hope this helps.
Two Stream Pucks (Both ethernet)
OGI 900 FTTP (900Mbs), eero Max 7 & 3 x eero Pro 6E
If my post has solved your issue please mark as an "Answer"
This message was authored by nmbailey This message was authored by: nmbailey
Seems to vary by brand. The Stream remote on my ancient Sony TV turns the set off but the one attached to my (newer) Panasonic doesn't.
This message was authored by MartinMedforth This message was authored by: MartinMedforth
Out of the box Remote for Sky Stream configured easily to control Panasonic TV (volume and on/off)
Needed reconfiguring and this time had to select TV model but whilst volume works it's no longer controlling on/off
Why oh why??
Any help folks???
