Discussion topic: Sky stream remote
This message was authored by: LauraSell89
Sky stream remote
Is there anyway to turn off the light up button mode? It's absolutely draining the batteries and I'm having the change them atleast twice a month.
Re: Sky stream remote
@LauraSell89  Unfortunately not.  I once had a remote where the batteries only lasted a couple of weeks and Sky replaced it for me. What you are experiencing is not normal so try requesting a replacement at  Streaming TV replacement remote  (You will need to sign into your MySky account).
My remote told me to change batteries about 10 days ago but instead of changing them I re-paired the remote and it is still working with the old batteries.  Give it a try you never know it might give you some additional time.  Also if you have a Sky Q remote tucked away in a drawer this works fine with Glass/stream.
Avatar for LauraSell89
Thank you for taking time to reply. I'll look into replacing the remote to see if it makes a difference.
