2
This discussion topic has been answered Discussion topic: Sky stream remote
This message was authored by: nahmed
Sky stream remote
Hi
Ive just received my sky stream stuff and I pulled the paper in the remote as said and it got torn.  I cant see a way to open the remote  which I tried to. The contact is not there in the remote so it wint work. How do I take out the paper inside the remote.  The paper was not strong enough.
Please help thanku
This message was authored by: mikealanr Answer
Re: Sky stream remote
Hi @nahmed
The back cover slides down. See: https://www.sky.com/help/articles/remote-control-help-sky-glass#:~:text=Re-pair%20your%20remote&text....
The first few times the back cover can be very stiff and hard to remove but persevere and you can work it off. I found putting it down on a cushion face down gave extra grip enough to get the back off.
Also a useful video: https://m.youtube.com/watch?v=P3ZbkLoJT0M
MikeAlanR
Hi @nahmed
MikeAlanR
Avatar for nahmed
Hi@MikeAlanR
Many thanks for the reply. Its so  hard but managed it but next time will do the way you said keeping on some support.
The video looks easy but its not that way!
 Thanks again!!
