24 Jan 2024 11:44 AM
Remote not working tried pairing it and it says connect but still not working and changed the batteries
24 Jan 2024 12:33 PM
Posted by a Superuser, not a Sky employee. Find out more@Jules11 To help you try to get your remote working the links below are to remote troubleshooting guides:
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth. Even though it sounds an unlikely solution it has got many faulty remotes working again (including mine on two occasions).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you have one available you can use a Sky Q remote while you wait for a replacement.
