Discussion topic: Sky stream puck
This message was authored by: ChrisH12
Sky stream puck
My sky stream puck keeps going wrong. I have to reset it at least three times a week, did not have a problem when i was with Virgin
This message was authored by: Stephen+Mourton
Re: Sky stream puck
@ChrisH12   The stream pucks are highly reliant on a good strong signal, and not just a high speed.  Are you connected to your router via an Ethernet cable?  Usually when they are connected this way these problems occur a lot less.  It not then make sure your router and puck have a clear line of sight to each other with no objects in the way, and the router is not on a window sill, and no objects close to the router or the puck.  That usually provides a more stable signal.  I hope that helps.
