Discussion topic: Sky stream puck
This message was authored by: Danielle148
Sky stream puck
My sky stream puck just will not turn on, there is no light. I have tried everything that sky have reccomended and still nothing.
This message was authored by: peter-marlow+1966
Re: Sky stream puck
How long have you had your  puck, and have you tried  the following trying  it in a different plug socket, and have you  changed the  fuse in the plug, is the power  cable pushed in fully is the power  cable  damaged
P c marlow
Re: Sky stream puck
I know you have said you have tried everything.
But, do try the recovery procedure (sometimes it needs trying it a few times) as detailed in step 4 in this Sky help article;
https://www.sky.com/help/home/sky-tv/sky-tv-stream/fixing-a-problem-sky-stream/fixing-sky-glass-sky-...
