5
This discussion topic has been answered Discussion topic: Sky stream puck will not connect wps
This message was authored by: Zoë_C
Just received a new sky stream puck and trying to set it up. Issue with connecting it to wps.
WPS button on router just flashes red. Is the device just faulty? Is this fixable?
This message was authored by: mikealanr Answer
Re: Sky stream puck will not connect wps
Hi @Zoë_C
So just checked a screenshot on the support site and WPS icon is there so should work. You need to select the open "sky broadband cusotmers (other broadband customers can also select this to connect using WPS)"
https://www.sky.com/help/home/sky-tv/sky-tv-glass/setting-up-sky-glass/articles/setting-up-sky-glass
You should screen this screen. Iwould do this before you press the WPS button on your router.
If that doesn't work Sky recommend this troubleshooting: https://www.sky.com/help/articles/connect-tv-help-sky-glass-sky-stream-puck
MikeAlanR
Hi @Zoë_C
When you set up the WiFi on the puck it asks you to choose Sky Broadband or other Provider. It then asks you to select the SSID (name) and enter the password. Not sure if it supports WPS.
https://m.youtube.com/watch?v=oxVeo8adcnQ - this is Sky's set up video and they only mention entering the password.
When I set my pucks up I entered password for non Sky broadband, so not sure what the sky broadband option does. The password for the WiFi should be on the bottom / back of your router.
MikeAlanR
Avatar for Zoë_C
It doesn't ask for any details, just to hit the wps on the router so I can only assume its supported.
This message was authored by: Deedee36
@Zoë_C  what message is on your screen?
“Trying to help improve sky glass”
Hi @Zoë_C
MikeAlanR
Avatar for Zoë_C
@mikealanr yeah that screen is exactly what I'm getting but the wps just flashes red and won't connect.
Certain I set up my glass through wps and other puck no problem.
I see there is another option to use WiFi settings instead so might try that later.
