Discussion topic: Sky stream puck not connecting
This message was authored by: Joy35
Message posted on 27 Jun 2025 04:13 PM
Got the following error message:
Let's get connected
we can't connect to your internet
✔️connection to broadband router
X connection to internet
My Internet is newly set up and seems to be working fine on my phone...
Message posted on 27 Jun 2025 04:58 PM
Re: Sky stream puck not connecting
@Joy35 Have you tried restarting your router and puck?
Either way, if your router is near the Puck most would recommend using an ethernet cable to connect. It gives a more stable connection and doesn't get the interference that WiFi is prone to. If connected via ethernet turn off WiFi in the Settings.
