Discussion topic: Sky stream puck longer power plug
This message was authored by: Blueyshe
Where can I get longer power supply for stream puck?
Re: Sky stream puck longer power plug
@Blueyshe  The official Stream Puck power supply comes as standard and there are no other options available from Sky.  There is nothing to stop you using an extension cord or a simple adapter in the TV socket.
Avatar for Blueyshe
That what my plan was but worry that it be short from puck to extension plugs. But I have to get my nephew to sorted it out for me when tv goes up on wall.
Thank you for yor reply much appreciated.
@Blueyshe it is recommended not to hide the puck behind the TV as that inevitably reduces wifi signal strength. The puck is designed to be used horizontally linked by a HDMI cable.
