Discussion topic: Sky stream puck lagging
Message posted on 11 Feb 2026 02:08 PM
Message posted on 11 Feb 2026 02:11 PM
Re: Sky stream puck lagging
@LisaMid How is the puck connected to the hub/router? On the puck open the Netflix app, go to Get Help, run connection test, what speed is being reported on the puck?
Message posted on 11 Feb 2026 02:14 PM
Just checked netflix its running at 85.29, its connected through WiFi as my hub is in the hallway
Message posted on 11 Feb 2026 04:39 PM
That should be enough, have you tried a restart of the puck?
Message posted on 11 Feb 2026 06:15 PM
As above, that speed should be good, if the puck can keep that speed regularly and it does drop lower now and again.
Try doing a settings restart;
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete.
Different ways to get to the settings menu;
Hit the . . . button on your remote and select settings, use voice saying 'settings' or scroll down to the settings menu on the home menu.
