9
This discussion topic has been answered Discussion topic: Sky stream puck keeps freezing and crashing
This message was authored by: Pet
Hi all I've just moved to sky broadband and tv and the sky stream puck I've been given keeps crashing while watching tv and then crashes so am having to keep turning it on and off again. Have checked the speed it's receiving and it's 220 mbps so don't think it's a issue with broadband speed. There's on other devices nearby such as a cordless phone or anything that I think could be causing interference. It happens at least 2 to 3 times a day. Any advice appreciated. Thanks.
Avatar for Pet
This message was authored by: Pet Answer
Re: Sky stream puck keeps freezing and crashing
Thanks for all your help with this. I've been I'm contact with sky now and have received a new puck which is working great now. Thanks again.
This message was authored by: Jporch316
Hi @Pet
@could be a faulty puck - try pulling the plug for a few minutes
if that doesn't work report back and I will escalate your post to the online support team
Avatar for Pet
Thanks for getting back to me on this. I've tried unplugging and also restarting via the settings but it's still crashing and sometime won't switch on using the remote so have to unplug and replug to switch it on again. If this could be escalated so I can get a replacement that would be great.
@Pet
I have escalated your post to the online sky community support team
Please lookout out for an invitation to chat with them
This message was authored by: Lisa-P1987
Thanks for escalating this. We’ve sent Pet  an invite to chat.
Please be aware conversations automatically close if there is no response within 48 hours.
Lisa - Sky Tech Team Expert
Avatar for Pet
This message was authored by: TrumpingtonCamb
We received a new puck, but the problem is still there....
frustrating, very frustrating....
This message was authored by: skiies
I have exctly the same problem - Sky replaced the puck and the problem persists. It is now so bad that we just cant watch TV through the Slky stream puck. I will have to contact Sky and see if they can replace it again. This is simply awful as I have wasted hours  reconnecting, bypassing my mesh router, connecting directly vid cable and still problem persists
@skiies
Why are you bypassing your mesh ? Should work fine off a mesh WiFi system .......
It was simply to check if it was my mesh that was causing the problem. So connected by wifi direct to router and then via ethernet cable all with same result. Virgin is my internet provider, and I get 200mbps down fibre and 30mbps up.
