2
This discussion topic has been answered Discussion topic: Sky stream puck issues
This message was authored by: Rzv
Hi .
I've just received my puck stream and I doesn't work (it should be straightforward, plug and follow the instructions ) .
On this device shows the message "software error ".
I have followed the instructions to reset the puck and the remote , the puck is flashing different light colors and its updating its software. Now how it's updating its software if is isn't connected to the internet?  Then it's shows the message if the update doesn't work please contact team support. I texted to contact team support but are available from Thursday to Saturday.
It's a faulty device or can be fixed ?
This message was authored by: Dazzasky Answer
Re: Sky stream puck issues
@Rzv wrote:
Hi .
Try following these instructions to see if it fixes the problem @Rzv
@Rzv wrote:
Hi .
Avatar for Rzv
All sorted , I've called customer service
(took 90 min , 50 min waiting for someone to answer )
Had to connect the puck straight to Ethernet cable and let it update its software, then I had to unplug it twice because didn't want to connect to WiFi and shown error messages , but at the end sorted
