Discussion topic: Sky stream power cable not long enough
This message was authored by: Ema999
The sky stream power cable isn't long enough to plug into my socket. I don't want an extension lead draped across the floor to be able to plug it in, can I get a longer (3m or 5m) 5v cable?
Re: Sky stream power cable not long enough
Afraid not.
This message was authored by: HavencroftKev
How is your TV and other potential devices plugged in?
Avatar for Ema999
I've bought a longer power cable for the tv
This message was authored by: pilgrim44
have a look on amazon. i bought  a stream extension cable from them.
This message was authored by: Jon34
I think it's a 1.35mm DC plug if that's any help to you
Avatar for Ema999
It is thank you 🙂
