2
This discussion topic has been answered Discussion topic: Sky stream playlist issues
This message was authored by: morayman20
My playlist occasionally displays programs I have not added and I cannot remove.
I have had a random Kevin mcloud program on the list for months and have tried adding then removing but it just stays.
Now I have 2 more that have randomly appeared. How can I remove them? I know it's not doing any harm them being there but it really bothers me.
This message was authored by: Stephen+Mourton Answer
Re: Sky stream playlist issues
I don't understand why the programs keep appearing, unless someone else in your home accidentally adds them.  With regard to removing them how are you trying to do that?
One way is to go to 'Playlist' and select the main circle that has the word playlist underneath it, page down and you will see 'Manage Playlist'  If you go into that you can select the program you don't want and delete it.
Avatar for morayman20
That's worked thank you.
I was pressing the plus button which usually removes series as well as adding them but wasn't working. Thank again.
