Discussion topic: Sky stream picture issue
This message was authored by: Jcostello
The picture is pink i have rest the puck tried different hdmi cables and different tv but the screen remains pink
Re: Sky stream picture issue
Hi @Jcostello
It sounds like a faulty puck. I have escalated your post to Sky who will reach out to you. Pucks are generally loaned to you (unless purchased before Feb 2023) so come with an unlimited warranty.
 Look out for a blue speech bubble as outlined here: https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
MikeAlanR
Avatar for Jcostello
Appreciate that thank you for your help
This message was authored by: CoffeeDrinker
Sometimes HDR/Dolby Vision issues give a characteristic pink and green screen. If you still have your Sky Stream puck connected and you are using a 4K TV, trying setting the picture output from 2160p UHD to 1080p HD temporarily. This should also turn off any HDR. If the picture looks normal in HD, the issue might lay with how your TV is handling HDR ( HDR10, HLG and/or Dolby Vision)
Sky Glass & Stream Puck customer w/Sky Entertainments & Netflix, Sky Cinema, Whole Home & UHD/Dolby Atmos add-on.
This message was authored by: Tom-W19
Thanks for escalating. We've sent an invite to @Jcostello.
Tom
