Discussion topic: Sky stream on portable display
This message was authored by: DJBimage
Hi, i have a Chromebook and the sky go app does not work properly deleted it loads of times re install it but does not really work well, anyway the reason for this thread is because we have now got sky stream and was thinking of getting another puck and connecting it to a portable monitor so I can watch it in the living room while the wife watches her bloody soaps🤷🏻so my questions are as follows
1. Can you have 2 puks in the same roam with the remote's controlling each puk individually.
2. Will the puk work on a external monitor ( which has an hdmi input)
3. Can I connect headphones to the puk itself.
Many thaks
Re: Sky stream on portable display
Yes, each puck has its own Bluetooth connection to the remote so once paired they only control the linked device.
Yes, you can connect it to an HDMI monitor as long as it supports HDCP 2.1 or better, check your monitor specs for that.
No, you can't connect headphones directly. You'd need to plug into your display.
