Discussion topic: Sky stream not working
This message was authored by: Linda1235
Message posted on 03 Dec 2024 08:29 PM
Just saying please wait for your program to load
Find out more
Message posted on 03 Dec 2024 10:00 PM
Re: Sky stream not working
Hi @Linda1235
This usually points to connection issues. Try turn off at the mains for a few minutes in the first instance. Failing this does your broadband meet the minimum requirements of 25Mbps for HD and 30Mbps for UHD? You can check the speed your puck is getting by opening netflix, going to get help? And selecting connection check.
MikeAlanR
