Discussion topic: Sky stream not working - says technical fault
This message was authored by: PaulD1969
Sky stream not working says technical fault
This message was authored by: Dansablade
Re: Sky stream not working - says technical fault
I keep getting this a lot too. I find just switching the box off at the plug and turning it back on again helps. Well for while anyway.
