Discussion topic: Sky stream isses
Message posted on 01 Feb 2026 06:59 PM
Sky stream isses
Using Sky stream with new LG G4
Last week we had a total outage on our new build estate for 8 hours
Still we were re connects I ve been having issues with the stream
Keep losing picture and getting usual please wait etc
Reset and loaded password numerous times it has become unwatchable
On settings shows poor connection and then drops out .
Alexa phones etc work fine
Has worked pretty much fine in the 3 months we have been in new house until after the outage
Puck located behind wall mounted Tv
Hub connections are located in a cupboard in hall. As said has worked fine up till outage.
Have opened cupboard and leave hub in hallway and seems a lot better but cannot keep it out in hall.
Would an wifi extender be useful
Tia
Message posted on 01 Feb 2026 08:08 PM
Re: Sky stream isses
Hi @Bolty323
It's likely that your router is now using a different channel chanel than it did previously. The best option would be to use ethernet cable / homeplugs. It's not recommended putting a router in a cupboard as you mentioned the signal is better when not in said cupboard. They are designed to be out in the open.
MikeAlanR
Message posted on 01 Feb 2026 09:30 PM
@Bolty323 wrote:Using Sky stream with new LG G4
Tia
In addition to the advice already provided, its also not advised keeping the puck behind a wall mounted TV, and that will also affect the Wifi connectivity and cause some connectivity instability.
Message posted on 01 Feb 2026 11:03 PM
Thanks for the reply. My problem is the cupboard is where the bband output to plug the router into is situated
