Discussion topic: Sky stream delay
Message posted on 03 Aug 2025 05:34 PM
Sky stream delay
My sky stream is about 1 minute behind. I'm on the second best sky wifi but yet it's still this far behind. I mainly use the tv for sport which is why it's an issue.
my contracts up in September, how do I get it changed to sky Q instead because I can't do another year of this.
Message posted on 03 Aug 2025 05:37 PM
Re: Sky stream delay
Thats how streaming works, there will be a delay compared to satellite or DTT
Message posted on 03 Aug 2025 06:17 PM
@Mead1 wrote:My sky stream is about 1 minute behind. I'm on the second best sky wifi but yet it's still this far behind. I mainly use the tv for sport which is why it's an issue.
Your WiFi speed will have no effect on live sport latency. It's just how the streaming service works. It takes longer for live sporting events to be encoded, uploaded and streamed from Sky's servers than it does to bounce off a satellite and be delivered to a dish and Q box.
If you'd prefer Q then give Sky a call - they will still switch customers having problems with Stream onto Q.
Message posted on 03 Aug 2025 07:01 PM
Even SkyQ has a 7-10 second delay, better than Stream, certainly. Mind the Sky Sports Low Latency channel on 922 does improve things.
Message posted on 04 Aug 2025 08:19 AM
@Mead1 it takes a finite time for a stream to process and toreach your puck so streams so are slightly behind satellite and terrestrial broadcastscwhich are again slightly behind the event at the venue if you want the fastest broadcast listen to FM radio.
The delay is actually about 30 seconds behind satellite according to my own tests (which match ehat Sky say themselves) but Sky are trying to reduce that delay and their llow latency channel is only roughly 7 seconds behind satellite but does appear to require more bandwidth than the standard stream so can cause issues for some customers. See here for more https://www.techradar.com/streaming/sky-tv/what-is-sky-sports-live-sync-the-new-low-latency-sports-s...
Message posted on 21 Oct 2025 12:13 PM
This is one of the reasons why I don't want stream...also because of the lack of ability to record but the Sky Q seems to have gone excessively expensive now. Stream is much cheaper but I'm just not happy with the delay.
At the moment I'm cancelling my subscription and ending up without anything. If only the would apply stream prices to Sky Q.
Message posted on 21 Oct 2025 12:35 PM
@n1ckarla wrote:This is one of the reasons why I don't want stream...also because of the lack of ability to record but the Sky Q seems to have gone excessively expensive now. Stream is much cheaper but I'm just not happy with the delay.
If you contact the Win Back team at Sky the day after your current Q service ends and the service stops, they will likely offer you a new, very good contract to stay on Q.
Message posted on 21 Oct 2025 01:39 PM
How do you contact the win back team?
Message posted on 21 Oct 2025 02:35 PM
Message posted on 05 Nov 2025 09:24 AM
"Even SkyQ has a 7-10 second delay" - not for me. I chat to people actually at F1 races as it's 1-2s off live proper. Still loads better than the 20s delay on Sky Stream
