1
This discussion topic has been answered Discussion topic: Sky stream connection drop.ping Hopefully solved.
This message was authored by: AmdySands
I had problems from the word go with my stream set up.
Every morning it would not connect to internet without reset.
Wired or wi-fi samee issue.
Sky services tried to blame my third party network but I knew this was not an issue. (Wi-Fi 7 TP Link Deco 500mbps).
After trying all sky recommendations, (Which did not work), I have played with settings and it seems the answer is to give all pucks/Glass a static IP from your router.
So far...........problem solved.
This message was authored by: ItWasAllMichele Answer
Re: Sky stream connection drop.ping Hopefully solved.
Posted by a Sky employee
