4
This discussion topic has been answered Discussion topic: Sky stream compatibility with 4G mobile network
This message was authored by: ERadford
I am moving from a property with full fibre but no mobile network, to an area that has ok 4G and 5G signal but no provider can give me more than 1-2mbps download speed.
I have no choice but to get either get satellite,  4 or 5G mobile broadband depending on which will work best and wondered if anyone uses thier Sky stream through satellite broadband or  mobile data and if it's compatible. Thank you
This message was authored by: Nigelb1972 Answer
Re: Sky stream compatibility with 4G mobile network
Stream should work over any internet connection providing it's stable and meets the recommended speeds..
This message was authored by: D+Hig
I use 3 mobile broadband and that works great with or without Ethernet but the latter is definitely better as more stable
Avatar for ERadford
Thanks so much for the advice
This very much varies from place to place. One issue you may find when using mobile broadband is that the speed is good, but latency is poor. This will affect stream
