Discussion topic: Sky stream add whole home
This message was authored by: Jen_89
Can someone advise how I can add whole home onto my sky stream account. I'm finding it impossible to do, every time I think I'm on the right lines it's about Sky Glass.
thanks.
Re: Sky stream add whole home
@Jen_89  Are you logging into your account 1st?   You should be able to add whole home & a puck through your account when you're logged in.  Manage your Sky TV - Home set-up
Avatar for Jen_89
Thanks for your reply! Yes, all signed in but when I go in to home set up and click the whole home it seems to only take me to options for sky glass.
This message was authored by: Hunter2660
Do you want to add an extra puck, or do you have more than one already?
Avatar for Jen_89
I currently only have one box and room with sky in it. Thanks.
So are you trying to add Whole Home for the extra Sky Go options below or wanting an additional Sky Stream puck?
For Sky Go adding Whole Home allows you to also watch on four devices at the same time on the Sky Go app and on your games consoles.
