1
This discussion topic has been answered Discussion topic: Sky stream add programs from euro. Sports to planner
This message was authored by: Ado1701.
Can yiu add programs from euro sports channel to planner
This message was authored by: Fothergill1 Answer
Re: Sky stream add programs from euro. Sports to planner
@Ado1701. Yes you can add programmes to your playlist from both Eurosport 1 and 2.  I do it quite often.  Sometimes, depending on the programme,  it will default to Discovery + for playback.
