Discussion topic: Sky stream Ultra HD
Message posted on 07 May 2026 06:21 PM
Sky stream Ultra HD
Looking for some advice,
I've just purchased Sky Stream , and paid for the ultra HD pack.
However, when I went to set up , did everything according to the set up video
(except connecting Ethernet Cable )
and when I selected UHD 2160p and clicked save changes , my screen would then start to flicker on and off , as if it can't watch it.
but when I then switch it back to 1080p HD
it seems to be fine.
then I look in the MySky App , but it says that my connection status is poor.
my tv is a Samsung 55" UHD and used to work fine with skyq.
Message posted on 07 May 2026 07:59 PM
Re: Sky stream Ultra HD
I had this issue with my Hisense TV's. The screen would flicker on and off when the puck was set to UHD. I had to adjust a setting on the TV to fix it. There is an option to change the HDMI cable speed, my TV was set to advanced but I had to select standard. The issue continued when selecting auto.
Router? Two TP-Link Deco BE65’s (v2 / Firmware Version: 1.3.5)
Message posted on 07 May 2026 09:05 PM
So is it ok now .
Message posted on 07 May 2026 09:27 PM
Yes, since selecting standard on my Hisense TV's all three work perfectly.
Message posted on 08 May 2026 07:36 AM
And did you / are you using the HDMi cable that sky supplied you with?
as I've tried a high speed 4K one and the puck / picture said that their was no signal and went straight over to HDMI port 2
thsbks
Message posted on 08 May 2026 07:49 AM
No, I'm not using the Sky supplied HDMI leads. I got mine from Amazon a few months back and I believe they were 8K certified.
