Discussion topic: Sky puck voice control
This message was authored by: Holtee
Small problem. When asking for sky news , Sky Sports news hd always comes on. This didn't used to happen and all other channels asked for seem to work fine. Anyone else had this happen and is there a fix. Thanks.
Re: Sky puck voice control
Yes seeing same.
I often use that to go to Sky News channel.
It certainly worked fine a few days back.
Your best bet to get this checked and resolved by Sky is to send an email to the Sky Viewer relations team to report it;
[email protected]
They do respond to emails with any updates for your queries or problems.
Hi @Holtee  Mine is the same today and I have reported it to [email protected] It usually works fine so must just be a temporary glitch.
Avatar for Holtee
Thanks all. Good to know it's not just mine. I did call Sky technical support but they said nothing they could do. Hopefully just temporary.
This message was authored by: lez4u2
Same problem, have contacted  [email protected]
Avatar for Holtee
I've done the same Lez4u2 👍🏻
Hi @Holtee  and others. As mentioned in an earlier post I reported this to Viewer Relations and I have now received their reply.  They agree this is happening and have reported the  issue to the relevant team to have this corrected.
They have discovered that if you leave the "S" of news and just say Sky New it will take you to Sky News and not the sports news.  I tried it and it works.  Weird to say the least.
Avatar for Holtee
Thanks all for replying. All working normally now. The Sky New did work too. Thanks again
