Discussion topic: Sky puck reset
Message posted on 17 Jun 2025 09:55 AM
Sky puck reset
My sky puck was not switching on this morning, done the reset as advised and now it's been on the 'sky stream' screen for nearly an hour after doing an update.
Has anyone found a way to fix it or does it need replacing (and how easy is that to do through sky?)
Message posted on 17 Jun 2025 11:44 AM - last edited: 17 Jun 2025 11:45 AM
Re: Sky puck reset
Hi @Victoria333 .
I had something similar a few weeks ago when my puck was stuck on the Sky logo which ultimately resulted in my puck being replaced after the recovery process also failed multiple times.
Try looking the suggestions at the following link.
https://www.sky.com/help/articles/power-issue-help-sky-glass-sky-stream-puck
The last option in the link is the recovery process. If after this you are still having issues I would call Sky for additional troubleshooting.
Message posted on 17 Jun 2025 07:04 PM
Re: Sky puck reset
Sky won't troubleshoot it. They will just send you a new puck & hope the problem will go away. But it probably won't because the pucks aren't the problem
Message posted on 17 Jun 2025 09:03 PM
Re: Sky puck reset
@TB18 wrote:Sky won't troubleshoot it. They will just send you a new puck & hope the problem will go away. But it probably won't because the pucks aren't the problem
@TB18 They asked me what I had already tried and then made a few other suggestions but in the end they determined that my puck had developed a fault. The new puck was received a few days later and was fully setup and running within 10 minutes of unboxing and luckily I have not had any issues since then 🤞. This would indicate that the puck was in fact the problem (in my case at least 😀)..
