08 Jan 2023 09:55 PM
Sky puck remote not working
We've tried resetting it by holding 7&9, 4&6, 1&3 and switching off the power. Replaced the batteries. Nothing is working.
any other ideas?
08 Jan 2023 09:59 PM
Grip the remote at both ends and give it a good twist as if wringing out a cloth. Keep an eye out for the backlight coming on as it comes to life.
Alternatively try manipulating the battery connection springs to ensure a better connection.
If neither work call Sky and ask for a replacement to be sent. If you have one use a Sky Q remote in the mean time.
Let us know how you get on.
08 Jan 2023 09:58 PM - last edited: 08 Jan 2023 09:58 PM
There are faulty remotes in the market, believe it or not taking the remote long ways in your hand and gently twisting it like wringing out a cloth often works.
Not sure why must be a dodgy connection inside.
Worth a try, other option call Sky for replacement.
03 Apr 2023 11:33 PM
Thanks @AntInBristol the towel ringing technique actually worked! ..... I thought this was a stupid prank haha but I'm all up and running! Thank you!
25 Aug 2023 12:57 AM
Nice 1 mate thought no way will it work but it did but only now I can go in the other room and control my other puck without having to press the relevant numbers ie 79 and 13 so cheers for that
16 Dec 2023 01:19 PM
I thought someone is taking the mickey here, 'twist it like ringing out a towel' - but hey if it's saves me £60 to replace two dead remotes what harm will it do - they're already dead.
Well blow me if it worked! That took me by surprise.
Shoddy electronics and a dodgy connection somewhere, shouldn't be surprised really.
16 Dec 2023 02:02 PM
@SeanWM wrote:I thought someone is taking the mickey here, 'twist it like ringing out a towel' - but hey if it's saves me £60 to replace two dead remotes what harm will it do - they're already dead.
Yeah it's solved it for a lot of customers. Bravo to whoever first discovered that "fix"
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
