Discussion topic: Sky puck issues
This message was authored by: QuaysGary
Sky puck issues
I am getting the "there is a technical issue with this channel" message on all channels. I have tried rebboting the puck but it hasnt worked. I am having this problem about eevry two or three days. Is there something else i can try. My internet speed according to Netflix (which works just fine) is 180 Mbs so connection speed is not an issue.
Re: Sky puck issues
@QuaysGary  How is the puck connecting to the hub/router?
This message was authored by: Jporch316
Re: Sky puck issues
Which internet provider are you with ?
Re: Sky puck issues
Do you run the Netflix speed check whenever it happens?
Avatar for QuaysGary
Level 2 icon
Re: Sky puck issues
Its connected over wifi - there is no way I can run an ethernet cable from the router to the TV
Level 2 icon
Re: Sky puck issues
im with Hyperoptic
