Discussion topic: Sky puck freezing
Message posted on 13 Apr 2025 07:19 PM
Sky puck freezing
Any idea why my puck keeps freezing and turning itself off? I thought it could be over heating but it's clear from anything.
broadband speed is 301mbps so isn't that either
Message posted on 13 Apr 2025 10:13 PM
Re: Sky puck freezing
Hi @Drummerman
What speed is your puck getting? 301 Mbps is your broadband speed, but quality between the puck and router is just as important.
Try opening netflix going to the left hand menu > get help > connection check. The puck needs to be getting 25Mbps for HD and 30Mbps for UHD. Try running a few times and taking an average.
Also be worth posting your ISP. Some issues with smaller ISPs and Virgin kit seems to be with DNS. Updating to use Google or Cloud flare seems to help. But I'd only do this once testing speed etc.
If the speed is above the threshold, it could be a fault with your puck. You will need to call Sky for a replacement (we are fellow subscribers here on the community).
MikeAlanR
55" Gen 2 Sky Glass atlantic blue, 65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Sky SoundBox. Former Sky Q, Sky+ HD and Sky+ customer.
Message posted on 15 Apr 2025 09:04 AM
Ahh thanks for this
connection speed via Netflix 214.59mbps
we use EE and the eero mesh system
