Discussion topic: Sky puck connection
Message posted on 28 Oct 2024 06:34 PM
Sky puck connection
Hi I have sky steam using a sky puck but lately it keeps loosing connection and saying no WiFi, but it is using an Ethernet cable.
done all the usual resets and unplug reboots but randomly looses connection.
any solutions or do I need a new puck ?.
Message posted on 28 Oct 2024 06:39 PM
Re: Sky puck connection
@Lynna82 wrote:Hi I have sky steam using a sky puck but lately it keeps loosing connection and saying no WiFi, but it is using an Ethernet cable.
Have you checked that WiFi is turned off on the puck's network settings?
If it is then it's probably worth trying a different ethernet cable before requesting a replacement puck.
Message posted on 28 Oct 2024 06:40 PM
@Lynna82 if you are using an ethernet cable turn off the pucks wifi facility in Settings/Network/Advanced which should help,with stability also in Settings/Start up and Standby set thr puck to remain networked in standby. Those changes should hopefully stop the issue.
Message posted on 28 Oct 2024 08:16 PM
Done all what you said made no difference.
